  • 5 Vote(s) - 4 Average
NICE MC800 Factory Reset
Anyone know is there a factory reset ability on the MC800 ?
The manual has instructions to reset memory settings to default by pressing the start and stop buttons simultaneously but this is not doing anything.
When I power up my MC800 I get the BlueBus flashing green but every 4 seconds approximately it also flashes red. Also L1 to L8 are all flashing red.
The motor leds M1 and M2 are both flashing green.
I disconnected the two grey block connectors leaving just the motors connected to the unit but that makes no difference, still all the flashing leds!
Anyone seen similar behavior?
Cheers
bg
A BLUEBUS flashing light 4X indicates, there is an intervention of the STOP input. Do you have anything wired into the STOP input like safety edges?
To do a complete reset you must press and hold down OPEN and CLOSE simultaneously for around 5-10 seconds. However, this will not rectify your issue, if it is a safety issue.
Easygates Ltd
When I disconnect everything and just have the motors connected to the unit I still have the same issue!
Brendan
(09-10-2023, 11:00 AM)bg148 Wrote: Hi,
Brendan
Hi Brendan,
now you only have the motors connected you can perform a factory reset by holding down Open & Close simultaneously for around 5/10 seconds.
 everything will flash and go out when the reset is complete.
then do a Blue Bus search and a position search with just the Motors connected.
Kind Regards
Matt
Unfortunately no joy, everything disconnected, and no reaction from the unit on the reset.
Brendan
(10-10-2023, 09:00 PM)bg148 Wrote: Unfortunately no joy, everything disconnected, and no reaction from the unit on the reset.
Brendan
Hi Brendan,
is there any chance you could give me a call on 01384569942 opt 2 please?
  Nice RB600 - Automatic close fail and opening issues P100D 1 769 30-09-2024, 02:43 PM
  Nice robus not closing Dantay 1 1,065 27-09-2024, 10:17 AM
  Nice Walky on 24v dman99 1 1,193 12-08-2024, 03:54 PM
  Can a Hormann Bisecur learn a code from a Nice ON2E? ? Noghar 1 2,048 17-07-2024, 02:21 PM
  Nice Era EPMB 3 flashes not recognised by control unit budda 2 2,204 16-07-2024, 08:47 AM
  nice robus D400 smartphone control YOSH 1 3,284 05-03-2024, 04:45 PM
  Nice MC800 Wiring issue Adamzsite 2 3,179 05-03-2024, 04:37 PM
  nice robus troubleshooting tarmongaidon 7 25,599 30-01-2024, 05:19 PM
Last Post: hasanova
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 4,697 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 3,903 01-11-2023, 09:45 AM
