  • 4 Vote(s) - 3.5 Average
Faac 455d Control Panel with XF868 Receiver
Hi I am installing an xf868 receiver to my 455d control panel but I am wondering is this quick connect as cables come loose when I connect up to power supply manually when pushed in. The receiver is 3 connectors but panel at quick connect is 5, ant help here would be great.
(29-10-2021, 02:20 PM)Dec Wrote: Hi I am installing an xf868 receiver to my 455d control panel but I am wondering is this quick connect as cables come loose when I connect up to power supply manually when pushed in. The receiver is 3 connectors but panel at quick connect is 5, ant help here would be great.
Hi I contacted the seller and I have been informed I got the wrong part by mistake so awaiting replacement. Hopefully this resolves the issue.
(30-10-2021, 07:50 PM)Decyep wrong type, need the other plug on board, that is is used on 24v boards Wrote:
Hi Dec,
Power will be wired into the receiver. You will then need to wire from the relay outputs to the push button/open input on the 455d panel. When the receiver is triggered, it will trigger the input, opening the gates.
-Jamie
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 706 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 701 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 1,523 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 1 1,547 12-08-2024, 03:52 PM
  FAAC problem dennisoates 0 1,275 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 4,399 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 4,023 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 4,929 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 4,658 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 9,581 21-11-2022, 09:54 AM
