  • 289 Vote(s) - 2.86 Average
Problem with Beninca R1.6E
Hi Terry,
These are relay photocells which work with a 'normally closed' contact. In order for you to test whether it is definitely the photocells causing this issue, you can bypass them by linking out the 'NC & C' on the photocells or the corresponding contacts they have been wired into on the control panel. If your gates start operating then I would recommend that you replace the cells ensuring some level of safety on there.
Kindest regards,
Dave
(29-03-2014, 05:28 PM)TerryDorset Wrote: I have a Beninca R1.6E which has been playing up. A couple of years ago I disabled the "magic eyes" because a periodic malfunction was stopping the gate from closing. I did this with microswitch 4 in the control box. Recently they have been constantly clicking on and off, so I removed the covers and cleaned out all the spiders, live slugs and assorted other muck. Since then the gate won't work at all. I have checked the connections and all seems okay. Could there be a problem with one of the pcbs? Is there a way of permanently disabling them at the control box? Thanks in advance for any assistance.
Terry
Problem with Beninca R1.6E - by TerryDorset - 29-03-2014, 05:28 PM
RE: Problem with Beninca R1.6E - by Blakey111 - 04-04-2014, 10:16 AM
RE: Problem with Beninca R1.6E - by TerryDorset - 04-04-2014, 04:50 PM
  Beninca actuator arm not moving at al Andruelectricgates 0 191 15-12-2025, 09:45 PM
Last Post: Andruelectricgates
  Beninca BOB30ME - Not closing all the way OMH 0 382 26-11-2025, 10:31 AM
Last Post: OMH
  Beninca TOM4024E wiring Shropshire_Lad 1 2,155 14-07-2025, 01:59 PM
  Photocell Problem marcoos_1 4 28,533 04-01-2024, 10:23 AM
  Beninca du.it14n Parko 1 4,271 24-08-2023, 01:38 PM
  Beninca bob motor wiring to board Ranch2 6 13,349 18-11-2022, 09:59 AM
  Master to slave remote problem Dingerb 0 3,787 24-12-2021, 01:26 PM
Last Post: Dingerb
  Proteco Leader N1 problem Luc Bevers 0 4,275 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,129 09-10-2021, 07:56 PM
Last Post: Shane1
  Beninca BOB21m Photo cell issue Rossm1987 1 7,697 02-05-2021, 12:39 PM
Last Post: Rossm1987
