  • 25 Vote(s) - 3.2 Average
Mag-lock not activating after close
(13-03-2025, 10:03 AM)Michael Wrote: Hi,
Firstly, I would check to see if the ELS output is giving out voltage (should be around 12v) once a command has been given.
Secondly, if the ELS is giving out voltage, check the relay to see whether it is switching from a NC to NO once the command has been given.
Mike
Thanks Michael,
I have checked that and the ELS does appear to be sending out voltage.  The lock is also powered at 12 v with the transformer and wires to it intact.  The challenge I am having is figuring out where the relay is in the system - could it be imbedded in the magnetic lock itself?  So I am wondering if the relay has failed or the lock has failed.  One of the somewhat disappointing things is every time I seem to open the Nice MC824H controller unit, I find another wire that is loose or broken, so when I fix it and re install the unit, with BlueBUS search, motor designation and positions search’s i get excited that I have sorted out the problem.  But it still does not lock the gate when closed with the electromagnetic lock and as such, the number one gates seems to bounce a little with closing and can trigger the photocell on the outside of the gate to start this close-open-close continuous sequence.  I have tried to set the maximum close position on the motor 1 to minimize this be cannot seem to easily set the position even with an Oview programmer interface.
Mag-lock not activating after close - by benkay - 17-02-2020, 11:39 AM
RE: Mag-lock not activating after close - by ldkerlukeHome - 13-03-2025, 04:19 PM
  Nice gates don’t close after the ambient temp is high Howard 2 8,358 15-08-2025, 02:01 PM
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,914 10-12-2024, 11:29 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 7,716 03-08-2022, 02:23 PM
  Auto close and hold open kensuth 1 7,706 14-03-2022, 11:49 AM
  Recommended lock for EL100 interface mrsgoggins 5 14,537 28-06-2021, 09:46 AM
  NIce Aria 400 unable to program gate open/close Telboy 2 15,969 13-01-2020, 03:33 PM
Last Post: Telboy
  Nice Remote - Lock out doctorrogeaton 1 13,048 18-05-2019, 08:39 AM
  Magnetic Lock to NiceHome Aria papekani 3 17,950 20-03-2019, 11:30 AM
  MC424 - close automatically once open maaarek 3 30,389 03-12-2017, 10:35 AM
  Gates open as soon as they close Craigp 4 83,774 08-01-2017, 05:04 PM
Last Post: Craigp
