  • 16 Vote(s) - 3.25 Average
Faac 415 can't reset from manual to operate mode
(08-01-2024, 11:43 PM)Stephen Q Wrote: Just had to replace large gate post and uninstall then reinstall faac 415.
Getting full electricity through as electro magnetic plate binds very strongly to lock leaf but when gate is activated to open it moves four inches and locks out. The cylinder arm is not retracting and prevents further movement then the system seems to lock out and I have to turn off and repower to reset but it repeats process.
I think the manual override is the problem as I can't reset out of manual. The release system just spins rather than going back to operational.
Hope that makes sense.
Does anyone have any similar experience?
Thank you in advance. Smile
Hi Stephen Q, were you able to solve this issue? I'm having the same problem. I had to manually override the opener due to power outage and now it will not re-engage. Any tips would be greatly appreciated.
Thank you!
RE: Faac 415 can't reset from manual to operate mode - by RXH - 18-03-2024, 01:20 PM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,603 11-11-2025, 03:33 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,291 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,334 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,938 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,626 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,807 22-04-2024, 03:21 PM
  Faac 455d Grantplant 1 8,006 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,736 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 12,316 21-11-2022, 09:54 AM
