  • 15 Vote(s) - 3.4 Average
Faac 455d
It may be worth trying to re-learn the limits for this motor. This is done by closing both leaves, --> enter BASIC PROGRAMMING --> select TIME LEARNING --> Then press the + button for 1 second. As soon as the leaves reach the opening contact point, give an OPEN command from your remote fob or pushbutton. Once you have done this, press push button F to exit and save programming.
However, it could possibly be a simple case of changing the opening time back to how it originally was. To me it looks like this has been changed which is telling the motors to operate for a longer amount of time which would cause the motor to keep running.
Many Thanks.
Faac 455d - by Grantplant - 11-11-2023, 04:24 PM
RE: Faac 455d - by Aiden Mitton - 13-11-2023, 11:58 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,603 11-11-2025, 03:33 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,292 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,335 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,938 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,627 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,811 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,429 18-03-2024, 01:20 PM
Last Post: RXH
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 12,316 21-11-2022, 09:54 AM
