  • 165 Vote(s) - 3.04 Average
Came gates stuck open.
(30-01-2023, 03:14 PM)Ring8180 Wrote: Hi Androidus,
My problem was the wires into the Pcb had worn and were shorting.
I originally changed the capacitors and it made no difference.
It was only when I took the cover off the pcb i noticed the outer casing on two wires had worn
I hope you manage to sort it
Martin
P.s if you do manage to sort it, perhaps post on here
What the problem was, that way it may help someone else.
Came gates stuck open. - by Ring8180 - 07-05-2018, 07:37 AM
RE: Came gates stuck open. - by Automatic-TC - 07-05-2018, 11:31 AM
RE: Came gates stuck open. - by Androidus - 30-01-2023, 12:08 AM
RE: Came gates stuck open. - by Ring8180 - 30-01-2023, 02:59 PM
RE: Came gates stuck open. - by Ring8180 - 30-01-2023, 03:14 PM
RE: Came gates stuck open. - by SamA - 03-02-2023, 12:12 PM
RE: Came gates stuck open. - by Androidus - 14-02-2023, 11:22 PM
RE: Came gates stuck open. - by SamA - 23-02-2023, 01:08 PM
  Gates not staying open JimM169 1 2,782 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,474 21-08-2024, 12:21 PM
Last Post: TheDock
  Nice MC824H gate stuck open Markp80 1 5,973 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 10,264 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 6,159 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 3,093 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,138 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 15,045 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 9,118 02-10-2023, 09:20 AM
