  • 33 Vote(s) - 3.52 Average
(14-07-2022, 04:10 PM)Beachcomber Wrote: Many thanks Sam. I now want to change my FAAC sensors to Beninca Pupilla sensors. Connecting to Beninca R1.6E motor as before. So it's Beninca to Beninca. My question is how to wire up. The FAAC RX sensor has four terminals but the Beninca RX sensor has five. The Beninca diagram is confusing. Two terminals on the RX sensor are labelled 24V AC (+) and (-) 24V DC. They leads go to the transmitter sensor (RX). where there are two terminals + and -. So far so good- I hope! (But why labelled AC and DC?) The other three Beninca terminals are obscurely labelled.  C is Common. NO is  'Normally Open'. NC is 'Normally Closed'. The NC is described as 'with powered and aligned photocells' and it shows a switch between the NC and ND terminals. What does all that mean for the wiring of the last two leads used by the FAAC sensor? There are other spare leads that were not connected to the FAAC RX sensor. Any clues appreciated.
Beninca have given me a terribly translated manual from italian. So from what i can interpret. You can pick up your power for your photocells from terminal 13 and 12. You wire from the NC on your photocells into 14. You wire from the C on your photocells into terminal 12 on the control board.
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,610 11-11-2025, 03:33 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,340 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,942 18-11-2024, 11:48 AM
Last Post: robhight
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,822 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,433 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 8,010 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
