  • 19 Vote(s) - 2.79 Average
FAAC NOT AUTO CLOSING. BROKEN WIRE
(21-07-2021, 03:00 PM)Slick19000 Wrote:
Hi.
I have a set of FAAC gates. They work on a master switch a sim card opening system where my phone opens the gates.
Everything was working perfectly until last week when the gates opened and closed ok but when the photocell was tripped the gates wont close unless you dial the number or flick the master switch.
I found the little white wire had broken off but cannot find the correct terminal to connect it back to.
Even with the wire not connected the gates open and close as they should. They only stop when the photocell is tripped.
Tearing my hair out in 30 degree heat.
Any help greatly appreciated.
I've images of the board and relay that triggers the sim card. Broken wire circled in red.
Do you know if this cable was used in the first place? As it might of never been used. If broken on one end, it should still  be connected into the board on the other end? If so, what terminal is this connected into? You can find this out by either belling it out, or simply tracing it back by hand.
-Jamie
RE: FAAC NOT AUTO CLOSING. BROKEN WIRE - by JoeF - 09-08-2021, 09:04 AM
RE: FAAC NOT AUTO CLOSING. BROKEN WIRE - by JamieF - 04-01-2022, 09:48 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,603 11-11-2025, 03:33 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,291 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,334 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,938 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,626 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,807 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,427 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 8,006 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,736 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
