  • 19 Vote(s) - 2.79 Average
FAAC NOT AUTO CLOSING. BROKEN WIRE
(21-07-2021, 03:00 PM)Slick19000 Wrote:
Hi.
I have a set of FAAC gates. They work on a master switch a sim card opening system where my phone opens the gates.
Everything was working perfectly until last week when the gates opened and closed ok but when the photocell was tripped the gates wont close unless you dial the number or flick the master switch.
I found the little white wire had broken off but cannot find the correct terminal to connect it back to.
Even with the wire not connected the gates open and close as they should. They only stop when the photocell is tripped.
Tearing my hair out in 30 degree heat.
Any help greatly appreciated.
I've images of the board and relay that triggers the sim card. Broken wire circled in red.
Hope you are well,
as colour code of cabling does not mean much in reality we will need to trace back where this wire had come from/ what it is connected to on the other end, would this be possible at all?
kind regards
RE: FAAC NOT AUTO CLOSING. BROKEN WIRE - by JoeF - 09-08-2021, 09:04 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,607 11-11-2025, 03:33 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,339 13-03-2025, 10:05 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,630 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,821 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,432 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 8,010 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
