  • 29 Vote(s) - 3.14 Average
Faac gate opens when photo cell beam is broken
Hi Stephen,
Photocells are generally used to stop and reopen gates when the are obstructed while the gates are closing. This is generally to avoid damaging vehicles which could be attempting to drive through as the gates start to close. It is not usually recommended to wire the photocells into the emergency stop command but I can explain how this is done below.
Going from the colours of the wires from the image you provided, you should have a green and white wire going terminal 12 and terminal 19, these will need to be removed and a wire bridge will need to be put between terminals 12 and 19. You will then need to remove the wire bridge from terminal 11 and terminal 14 and replace this with the green wire going to terminal 11 and the white going to terminal 14. If you already have wires going into terminals 11 and 14 you will need wire the 4 wires in series to allow the photocells and other STOP device to function.
RE: Faac gate opens when photo cell beam is broken - by RyanB - 17-03-2021, 11:36 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,611 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,604 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,294 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,343 13-03-2025, 10:05 AM
  FACC sliding gate not responding. Kipod 2 4,860 09-12-2024, 09:24 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,634 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,825 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,434 18-03-2024, 01:20 PM
Last Post: RXH
