  • 15 Vote(s) - 3.27 Average
FAAC 740 hums instead of working
Hi Turgut,
Have you re tested the voltage after the capacitor change? A humming motor with no movement usually relates to low voltage/bad capacitor or a low force issue. My concern is that you found the fuse protecting the automation to be popped. This does highlight that there could of been an issue electrically when the gate attempted to close which may have cause damage to the motor internally which is not allowing the motor to actually turn when it is engaged.
FAAC 740 hums instead of working - by tkalfaoglu - 04-02-2021, 10:53 AM
RE: FAAC 740 hums instead of working - by RyanB - 05-02-2021, 10:41 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,737 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,339 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,075 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,016 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,784 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,404 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,418 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,138 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,783 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,535 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
