  • 21 Vote(s) - 2.76 Average
FAAC 455D programming
(19-06-2020, 11:02 PM)Harrisbhreac Wrote: Hi all hoping someone would be able to help. My friend got decided to make his gates electric so got somebody to come and do it for him. The guy that started the job left my mate in the lurch and is avoiding his calls. He asked if I’d be able to do them as I’m an electrician, I told him I’ve never had anything to do with gates but agreed to help. I’ve got the 455d circuit board controlling 2 swing gates, with remote to open them. When pairing the remote was done we then went onto learning the gates which all went ok but when that was finished nothing happens with the gates when pressing the remote! Was wondering if anyone could help as contacted facc technical and had no luck from them. Thanks in advance
Hi, I had a similar problem (still have an issue), if you use a jumper lead between pins 11 and 14 does the gate operate? I also have jumper leads between pin 19 and 12 & 13 (see fig 7 in the installation manual). My issue now is that its not following the TL Complete sequence that I programmed (TL programme works perfectly).
Hope this helps
FAAC 455D programming - by Harrisbhreac - 19-06-2020, 11:02 PM
RE: FAAC 455D programming - by Henliston - 16-08-2020, 06:04 PM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,611 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,604 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,294 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,343 13-03-2025, 10:05 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,634 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,825 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,434 18-03-2024, 01:20 PM
Last Post: RXH
  FAAC 740 limited travel LoneStarCycler 0 6,738 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
