  • 129 Vote(s) - 2.69 Average
I found the diagnostics sheet and under Red Led "PHOTO" it states, " normally ON, it turns OFF when an impulse  is received on PHOTOCELL input. "   At the moment its unlit.  This leads me to believe that it may be a cell related fault.
HELP
RE: Gates TRIPPING rcd with internal open/close switch. - by JoeF - 06-12-2019, 11:10 AM
  Gates not staying open JimM169 1 2,780 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,474 21-08-2024, 12:21 PM
Last Post: TheDock
  Came Frog one side wont close PmIrl 1 3,636 13-05-2024, 02:40 PM
  Nice MC824H gate stuck open Markp80 1 5,971 13-05-2024, 02:32 PM
  Rigel 5 , gates won't open Nameloc 4 10,262 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 6,156 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 3,092 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,137 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 15,044 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 9,116 02-10-2023, 09:20 AM
