  • 14 Vote(s) - 3.29 Average
Came Frog one side wont close
Hi All
I have a pair of swing gates and one side is not close. If you stand at the gate and push it it will close but not on its own, i had this problem last year and adjusted the stop bolt on the driver arm to keep it back from the kerb this worked and last for 12 months but now wont work motor running but cant seem to get a grip of the gear to pull the gate without a push from someone. They are Came Frog A motors approx 7 years old very windy area. any help would be great. should i just buy new motor or what part may i need.?
Thank you for contacting us.
Could you let me know whether the motors you are using are 230v or 24v?
Aiden
  Proteco Q60 - FH error then close after opening Needlerp 1 6,074 24-06-2022, 09:54 AM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,962 12-01-2022, 08:13 PM
Last Post: Shane1
  Came ZLJ24Z - close immediately photocells are clear Enginear1 0 3,805 29-10-2021, 10:47 PM
Last Post: Enginear1
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,605 02-05-2021, 09:00 PM
Last Post: soother
  Gates TRIPPING rcd with internal open/close switch. bomitie 5 90,573 06-12-2019, 11:10 AM
  Frog A gate motors granddadbaza 1 15,007 19-08-2019, 05:23 PM
Last Post: granddadbaza
  SEA SWING 2DG gate won't stop tryin to close JohnCox 0 6,649 30-04-2019, 05:05 PM
Last Post: JohnCox
  Reccomendation: side gate automation GeorgieB1 1 11,252 19-09-2018, 06:49 PM
  Gate wont stay shut camberlan 1 12,004 09-10-2016, 05:23 PM
Last Post: frenchconnection67
  Electric motor hums and wont turn 9clarin 0 7,868 04-07-2016, 10:40 PM
Last Post: 9clarin
