  • 127 Vote(s) - 2.7 Average
CAME ZLJ24 panel - Open gate indicator-light
    Greetings friends!
Forgive me if I am posting in the wrong place..!!! I'm new here!
I would like more information about this 'open indicator-light'. I checked the installation/programming manual and can only find reference to it as being connected to 11 and 5 on the terminal rail.
I tested the voltage at 11 and 5 throughout a few open/close operations but failed to detect any voltage accross 5 and 11 at any stage. I was expecting to pick up 24vac when the gate/s begin to open or are completely open. I have read the programming section but only see reference to the cycle lamp / flasher lamp on 10-E
Is the Open gate indicator-light a bit of kit supplied by CAME??
What is its role in the operation of the gate.
regards
Dom
did you check dip-switch position ?
i got manual frome came zl160 and indicator light output is between 5 and 10 (24v 3W max)
regards
  Came ZM3E - Wont open from keypad geoff_n 2 539 09-01-2026, 03:47 PM
Last Post: geoff_n
  CAME F7000 Gate Openers Issue Jackolantern 7 10,936 03-11-2025, 08:46 AM
Last Post: Jackolantern
  Came ZA4 control panel Pat 2 5,672 09-05-2025, 12:30 PM
  ZLJ24 and AXO Motors gone awry colmgillard 1 5,141 22-04-2025, 08:19 PM
Last Post: Mibbo
  Trouble accessing ZLJ24 Control Panel Box chich 2 6,902 06-10-2024, 12:15 PM
Last Post: chich
  Came ZA3 Control panel wiring help and setting up help 7 56,538 24-09-2024, 03:29 PM
Last Post: merefield
  CAME ZLJ24 Control Panel SmtsFnd 5 11,959 08-05-2024, 08:57 AM
  ZLJ24 Reversed Paulgates 1 5,286 15-04-2024, 12:05 PM
  CAME sliding gate drops codes after power outage Catch 1 7,815 02-03-2023, 03:18 PM
  My Came ZM3E gates won’t open golfnut75 1 11,024 12-08-2022, 08:40 AM
