  • 289 Vote(s) - 2.86 Average
Problem with Beninca R1.6E
Sad
I have a Beninca R1.6E which has been playing up. A couple of years ago I disabled the "magic eyes" because a periodic malfunction was stopping the gate from closing. I did this with microswitch 4 in the control box. Recently they have been constantly clicking on and off, so I removed the covers and cleaned out all the spiders, live slugs and assorted other muck. Since then the gate won't work at all. I have checked the connections and all seems okay. Could there be a problem with one of the pcbs? Is there a way of permanently disabling them at the control box? Thanks in advance for any assistance.
Terry
Hi Terry,
These are relay photocells which work with a 'normally closed' contact. In order for you to test whether it is definitely the photocells causing this issue, you can bypass them by linking out the 'NC & C' on the photocells or the corresponding contacts they have been wired into on the control panel. If your gates start operating then I would recommend that you replace the cells ensuring some level of safety on there.
Kindest regards,
Dave
(29-03-2014, 05:28 PM)TerryDorset Wrote: I have a Beninca R1.6E which has been playing up. A couple of years ago I disabled the "magic eyes" because a periodic malfunction was stopping the gate from closing. I did this with microswitch 4 in the control box. Recently they have been constantly clicking on and off, so I removed the covers and cleaned out all the spiders, live slugs and assorted other muck. Since then the gate won't work at all. I have checked the connections and all seems okay. Could there be a problem with one of the pcbs? Is there a way of permanently disabling them at the control box? Thanks in advance for any assistance.
Terry
Hi Dave
Thanks for the reply. I'll bear it in mind when I've sorted a somewhat bigger problem.
I discovered power wasn't getting to the controller so I replaced the fuse only for that one to blow in a cloud of smoke! I've had an engineer out who has diagnosed the transformer being shot. Could be worse - could have been the motor!Sad
Don't know if my cleaning the photocells has had any bearing on the problem or whether it's coincidence. I'll let you know the eventual outcome.
Terry
  Beninca BOB30ME - Not closing all the way OMH 1 532 09-01-2026, 09:54 AM
  Beninca actuator arm not moving at al Andruelectricgates 1 317 09-01-2026, 09:49 AM
  Beninca TOM4024E wiring Shropshire_Lad 1 2,260 14-07-2025, 01:59 PM
  Photocell Problem marcoos_1 4 28,803 04-01-2024, 10:23 AM
  Beninca du.it14n Parko 1 4,412 24-08-2023, 01:38 PM
  Beninca bob motor wiring to board Ranch2 6 13,611 18-11-2022, 09:59 AM
  Master to slave remote problem Dingerb 0 3,866 24-12-2021, 01:26 PM
Last Post: Dingerb
  Proteco Leader N1 problem Luc Bevers 0 4,349 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,202 09-10-2021, 07:56 PM
Last Post: Shane1
  Beninca BOB21m Photo cell issue Rossm1987 1 7,813 02-05-2021, 12:39 PM
Last Post: Rossm1987
