  • 14 Vote(s) - 2.57 Average
Nice MC824H gate stuck open
Hi guys,
We have a Nice MC824H installed and recently it started to play up whereby the gates would stay open.
I ordered a new set of Nice EPMB photocells, fitted them and performed the blue bus learning procedure. This seemed to fix the gates and they started working again. However, I noticed the sensor on one side had no power and they do not stop the gates from closing when you get i  the way. I now tried to see why it waa getting no power to no avail and stopped the gates mid way. The gates are now stuck open again.
I have tried disconnecting the photocells and performing the rearning procedure without them but the gates remain open.
I found an old post that mentioned which lights should be on. Bluebus flashes green once per second, L3 and L4 are slowing flashing and Stop is permanently on red which I beleive is correct. However, neither ENC1 or ENC2 is lit.
Should they be and if not, what could be the problem? I opened up the junction box for the motor power and it is full of cobwebs. Wondering if it could be due to moisture or a fuse perhaps.
Thanks in advance for your help.
Mark
(12-05-2024, 01:15 PM)Markp80 Wrote: Hi guys,
Mark
Hi Mark,
This sounds like it could possibly be an issue with an encoder, I would advise checking for any loose connections on your encoders. However, if there is water ingress present as you have said it could be caused by this, otherwise this could have just been a malfunction of the encoder. If the encoder is faulty the motor may need replacing however.
Jake.
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 784 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,913 09-01-2026, 10:03 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,513 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,513 09-05-2025, 12:36 PM
  Nice wingo 5400 and MC800 engrbhadz 0 2,323 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 14,211 02-12-2024, 10:40 AM
Last Post: bing
