  • 19 Vote(s) - 2.53 Average
Rigel 5 - second keypad stopped working
Hi there
I’m a bit baffled.  I have a Rigel 5 system with two keypads - one at the gate entrance on either side of two electrified motor driven gates
All has been working fine for 4 years without issue.  Until one day the keypad with the camera lost its configuration and required setting up again - which was done by out maintenance company.
A year later the same has happened with the second keypad which is an SRS DC60. It has been programmed and when a correct 4 digit code is entered it appears to go through the motions however doesn’t activate the Rigel to open the gates. Power is showing, the green light appears when the correct code is entered.
When using the other keypad with a correct code - that activates the gates as expected
What am I missing please ?
Both are configured as NO.  However I did spot that in the panel with the camera - common is empty however on the keypad not working - there is a common wire connection
Have you tried metering the NO and COM, check to see if there is continuity. You could check for continuity between the cables too.
Mike.
  Digipro keypad 0161Geezer 0 2,206 22-03-2025, 07:16 PM
Last Post: 0161Geezer
  Rigel 5 , gates won't open Nameloc 4 10,281 04-05-2024, 12:41 PM
  Faac photocell stopped working Zeb Gulickx 2 8,344 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  BFT Rigel 6 stevew 3 6,665 29-08-2023, 08:39 AM
Exclamation Proteco Q60A stopped working xCO 0 3,516 19-06-2023, 01:03 PM
Last Post: xCO
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 12,206 02-12-2022, 02:51 PM
  Wired up but not working Ranch2 7 14,024 18-11-2022, 10:02 AM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,517 26-08-2022, 03:42 PM
  Faac 740 - stops working norberto 1 10,757 02-06-2020, 05:15 PM
Last Post: norberto
  Getting motors working together Rich123 0 8,992 22-09-2019, 04:44 PM
Last Post: Rich123
