  • 21 Vote(s) - 2.76 Average
FAAC 455D programming
Hi all hoping someone would be able to help. My friend got decided to make his gates electric so got somebody to come and do it for him. The guy that started the job left my mate in the lurch and is avoiding his calls. He asked if I’d be able to do them as I’m an electrician, I told him I’ve never had anything to do with gates but agreed to help. I’ve got the 455d circuit board controlling 2 swing gates, with remote to open them. When pairing the remote was done we then went onto learning the gates which all went ok but when that was finished nothing happens with the gates when pressing the remote! Was wondering if anyone could help as contacted facc technical and had no luck from them. Thanks in advance
(19-06-2020, 11:02 PM)Harrisbhreac Wrote: Hi all hoping someone would be able to help. My friend got decided to make his gates electric so got somebody to come and do it for him. The guy that started the job left my mate in the lurch and is avoiding his calls. He asked if I’d be able to do them as I’m an electrician, I told him I’ve never had anything to do with gates but agreed to help. I’ve got the 455d circuit board controlling 2 swing gates, with remote to open them. When pairing the remote was done we then went onto learning the gates which all went ok but when that was finished nothing happens with the gates when pressing the remote! Was wondering if anyone could help as contacted facc technical and had no luck from them. Thanks in advance
Hi, I had a similar problem (still have an issue), if you use a jumper lead between pins 11 and 14 does the gate operate? I also have jumper leads between pin 19 and 12 & 13 (see fig 7 in the installation manual). My issue now is that its not following the TL Complete sequence that I programmed (TL programme works perfectly).
Hope this helps
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,617 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,618 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,301 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,348 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,946 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,644 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,834 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,446 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 8,017 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,744 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
