  • 25 Vote(s) - 2.92 Average
Aria 400 - gates keep opening and closing
Hello fellow automation fans!
Turning to this forum as the troubleshooting in the Aria manual is a little limited.
I had a Aria 400 kit installed a month or so ago and its been working great.  A few days ago, it started continually opening.  There is nothing blocking the photo beams.  When I press the close button, the gates will close again but as soon as they hit the stop, they open again, and repeat, and repeat etc.
Eventually it stops and they stay closed.  The gates will open correctly on demand but once opened, again they will continually close and open for up to 10 cycles.  i do not know why and hope that some in this forum will be able to tell me.   there is nothing blocking the gates, and they will open fully and hit the stop, and close fully to the stop.  ( then open, close, open close etc)
Has anyone come across this or got any ideas on what i need to do other than a factory reset?
many thanks for your help and please feel free to call me out if im being daft and have not thought of something simple!
Objohnuk
(08-04-2022, 08:40 AM)objohnuk Wrote: Hello fellow automation fans!
Objohnuk
Thanks for the message,
this to me seems like an obstacle detection via the force limiter, essentially this means that the gate is "seeing something in the way" when the fault occurs could you take a look at the ECSBus to see how many times this is flashing.
Kind regards
  Beninca BOB30ME - Not closing all the way OMH 1 525 09-01-2026, 09:54 AM
  came bx-b clicking & not opening misssmith 1 3,313 13-03-2025, 09:57 AM
  Gate not closing thronetm 0 4,337 16-11-2024, 09:25 PM
Last Post: TheDock
  Rigel 5 , gates won't open Nameloc 4 10,262 04-05-2024, 12:41 PM
  Gates tripped Phil.c 3 6,156 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 3,092 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,136 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 15,037 07-01-2024, 07:11 PM
Last Post: Simon NW
