  • 23 Vote(s) - 2.87 Average
FAAC 740
I have recently installed a FAAC 740 gate and have 2 queries.
1) How do I turn off the automatic closing option?
2) The gate was working perfect and then yesterday it just started labouring when closing to sucha  point that it seemed under pressure and was barely moving. When I press the button it opens perfectly and smootly but the closing is the issue.
Please advise
change the logic to 'e' to take off auto close
have you set the limit sensors properly?as it would go in slow mode if it is looking for a limit sensor.
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,603 11-11-2025, 03:33 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,290 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,331 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,938 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,625 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,807 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,427 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 8,003 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,734 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
