  • 26 Vote(s) - 2.81 Average
Mhouse WS2 Gates not closing together
Since storm Eunice battered the gates, they will not close together first time.
They appear to close and then a second or 2 later, they start to open again. If you stop them mid re-opening and close them again, they close on the second attempt but do not sit 100% level together as they used to.
How do I re-synch them so they close together the first time?
Advice and/or web links appreciated.
Hi Paul,
1, Press and hold P2 & P3 together until STOP LED goes out (Resetting back to factory default)
2, Press and hold P2 for 3 seconds and release (Learning connected devices, Bus search)
3 When P3 start to flash, press and hold P3 until motor gate starts to move then release (Position search, learning of the opening and closing cycles)
Easygates Ltd
  Mhouse sl10 not closing Mark Reader 1 6,085 13-03-2025, 09:56 AM
  MHouse Sl1 does not open v.ptohides 1 6,103 03-02-2025, 09:56 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 7,973 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 10,220 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 8,527 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 31,108 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 14,087 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 8,372 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 16,811 30-05-2022, 09:15 AM
  Mhouse WG20 Alex74 1 9,856 04-02-2022, 11:05 AM
