  • 32 Vote(s) - 2.56 Average
Gates Opening After Closing
I am having a problem with my FAAC gates (245 board). The issue is that the gates will automatically open on their own about 5-8 seconds after they are closed. It seems to be that if the gates have been open for a while (over half an hour) then they will not reopen on closing. However, if you open the gates, go through, and then close them, they will reopen. You have to repeat the process another 1-2 times until they decide to remain closed. The temperamental nature of it is a real head-scratcher.
Any ideas what could be causing this? The photocells aren't configured at the moment but I don't believe this would be the cause.
Any help massively appreciated!
(15-04-2017, 07:39 PM)hi did you ever get this fixed, as i also have the same issue on a differnt board (BFT Libra ) my pair gates open again right away when they come to close and straight after a "Start" is sent to the board and the gates open? photocells all work as intended any help appreciated Wrote: Hi,
(13-10-2021, 04:47 PM)Hi,I having this same problem with faac 245 board. Did you guys found out the solution?  Thanks in advancegate-keeper Wrote:
  Beninca BOB30ME - Not closing all the way OMH 1 520 09-01-2026, 09:54 AM
  Gates not staying open JimM169 1 2,774 21-05-2025, 02:55 PM
  came bx-b clicking & not opening misssmith 1 3,311 13-03-2025, 09:57 AM
  Gate not closing thronetm 0 4,337 16-11-2024, 09:25 PM
  FAAC gates out of sync TheDock 1 3,473 21-08-2024, 12:21 PM
Last Post: TheDock
  Rigel 5 , gates won't open Nameloc 4 10,259 04-05-2024, 12:41 PM
  Gates tripped Phil.c 3 6,155 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 3,088 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,130 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 15,036 07-01-2024, 07:11 PM
Last Post: Simon NW
