  • 428 Vote(s) - 2.72 Average
Wind problem.....
#11
(11-07-2019, 04:05 PM)Pop Alexandra Wrote:
(09-10-2016, 05:46 PM)frenchconnection67 Wrote: A solution is a lock as you did but you need to set the board with the lock release function ON which makes the motor to force close for a 2 or 3 s to release any pressure of the lock before the normal cycle.
I tried this with 3 seconds and it works just fine. Thanks for the tip.
_______________________________________________________
Alexandra from https://revetementagro.com/produits/garage
That is great to hear.
  FAAC problem dennisoates 0 3,628 30-06-2024, 04:40 PM
Last Post: dennisoates
