  • 9 Vote(s) - 3 Average
Mhouse WG20
    Our gates suddenly stopped working one morning last week. We have tried all the advice already posted, including trying to do a full factory reset, but the ECSbus continues with 3 flashes, pause, 4 flashes, pause, 3 flashes, pause, 4 flashes, pause etc. the STOP led flashes about once a second. The key operated opening thing does not work either. Any advice would be greatly appreciated.
Alex
(18-01-2022, 05:55 PM)Alex74 Wrote: Our gates suddenly stopped working one morning last week. We have tried all the advice already posted, including trying to do a full factory reset, but the ECSbus continues with 3 flashes, pause, 4 flashes, pause, 3 flashes, pause, 4 flashes, pause etc. the STOP led flashes about once a second. The key operated opening thing does not work either. Any advice would be greatly appreciated.
Alex
Hi Alex,
Please see below for diagnostic LED flashes.
3 flash 1 second's pause 3 flashes Cutting in of the "motor force" limiting device During the movement, the leaf experienced excessive friction
You could try increasing the force.
4 flash 1 second's pause 4 flashes Cutting in of the STOP input During the movement the STOP input was activated; identify
Do you have anything wired into your STOP terminal? i wold remove all accessories from the board and just keep the motors connected, do a reset and relearn the Bus by pressing and holding P2 down for 3 seconds, put the gates into the half way position manually, lock them and do a position search by pressing and holding the P3 button down until the motor starts to move.
Mike
Easygates Ltd
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 687 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 1,521 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 1,627 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 9,076 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 4,125 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 3,471 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 7,561 30-05-2022, 09:15 AM
  Mhouse WS2 Gates not closing together pauln0301 1 5,319 13-04-2022, 11:18 AM
  WG20 Factory Reset ? tsmyth@iinet.net.au 1 4,476 28-09-2021, 11:01 AM
  MHouse WS2S Bricodust 2 9,546 30-03-2021, 01:26 PM
Last Post: Bricodust
