  • 4 Vote(s) - 3 Average
Mhouse left gate blocking full open when initialising gates
Hello
I have an issue with my mHouse WS2, it started with the left gate blocking at full open and not wanting to close.  If I released the mechanism, moved the gate a little then re-engaging the motor it closed ok. fyi, the right gate is moving fine but stops when the left gate should start moving.  during the initialisation cycle the closing  part of the works fine for both gates.
I've tried moving the end stop so the left gate doesn't travel so far and the results are the same - it blocks at fully open.
I checked the motor and everything looks ok - no build up of dirt, etc inside - and if I try moving the gate manually it moves freely over the whole range.
Is there anything else which could be causing the gate to get stuck at the full open position?
Hi Neil,
With the Nice Mhouse systems they have a diagnostic LED which is called the 'Bus LED' or bluebus etc.
If you can get this fault to happen again, when it is happening, just check this LED to see whether it flashes multiple times then a pause.
In standard operation, this will be flashing once per second.
If you could let me know how many times this is flashing, I'll be able to find out what fault the control board is trying to tell us.
Many Thanks.
Aiden.
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 547 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 1,341 30-01-2024, 10:35 AM
  Where can I find Electric sliding gate opener NICE ROBUS Spare Parts Mogahid Abbas 1 1,265 29-08-2023, 08:40 AM
  Mhouse SL1 won't close correctly Dartman 5 8,547 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 3,929 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 3,303 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 7,312 30-05-2022, 09:15 AM
  Mhouse WS2 Gates not closing together pauln0301 1 5,262 13-04-2022, 11:18 AM
  Mhouse WG20 Alex74 1 5,824 04-02-2022, 11:05 AM
  MHouse WS2S Bricodust 2 9,470 30-03-2021, 01:26 PM
Last Post: Bricodust
