  • 9 Vote(s) - 2.67 Average
Mhouse WS2 Gates not closing together
Since storm Eunice battered the gates, they will not close together first time.
They appear to close and then a second or 2 later, they start to open again. If you stop them mid re-opening and close them again, they close on the second attempt but do not sit 100% level together as they used to.
How do I re-synch them so they close together the first time?
Advice and/or web links appreciated.
Hi Paul,
1, Press and hold P2 & P3 together until STOP LED goes out (Resetting back to factory default)
2, Press and hold P2 for 3 seconds and release (Learning connected devices, Bus search)
3 When P3 start to flash, press and hold P3 until motor gate starts to move then release (Position search, learning of the opening and closing cycles)
Easygates Ltd
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 548 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 1,343 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 1,465 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 8,555 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 3,933 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 3,305 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 7,315 30-05-2022, 09:15 AM
  Mhouse WG20 Alex74 1 5,824 04-02-2022, 11:05 AM
  MHouse WS2S Bricodust 2 9,470 30-03-2021, 01:26 PM
Last Post: Bricodust
  MHouse WG2 Manual Release mousetarget 1 7,603 30-03-2021, 12:21 PM
