  • 34 Vote(s) - 2.85 Average
V2 Phox 2-Channel Remote Control
Hi Gate People
We are retiring to Spain (we're very fortunate I know!) and the house we are moving to has an Alfariss motorised gate already fitted.
During the sale process a set of keys and one of the V2 Phox 2-Channel Remote Controls 'disappeared'. I can easily change the euro cylinder locks but I am worried about the missing remote.
I can buy another remote from Easygates but how do I program it to work with the controller?
Is there a way I can prevent the original missing controller from opening the gate?
There is only one local motorised gate supplier I can find and he couldn't help so I would be very grateful if anyone on this forum could answer my questions.
Cheers - Moldy
During the sale process a set of keys and one of the V2 Phox 2-Channel Remote Controls 'disappeared'. I can easily change the euro cylinder locks but I am worried about the missing remote. I can buy another remote from Easygates but how do I writemyessay and program it to work with the controller?
Cheers - Moldy
Hi Moldy,
A weird situation with the "disappeared" controller I should say. The first to do is to reprogram the controller of the gate itself, because you can't be sure that the missing controller is actually lost and won't be used by anyone. Reprogramming should be better done by specialists.
You can, of course, do it yourself. On the Internet, there are very detailed instructions how to reprogram the gate controller. But there may be a lot of pitfalls, there are a lot of nuances that you need to know, you need to have special devices to connect to the controller and there is a very high probability that you can turn the controller into a dead metal chunk (no offense).
(20-01-2019, 01:41 PM)moldy1 Wrote: Hi Gate People
I can buy another remote from Easygates Essay-Professors reviews but how do I program it to work with the controller?
Cheers - Moldy
That is so weird and not so pleasure situation, because that remote could be stolen. First of all you need to reprogram your system, you can do it by yourself but it would be better if you called to the service center and they do everything instead of you
HI,
In order to ensure our remotes are compatible you will need to look at the rear of the remote and look for the numbers contr 694
if so that means our remotes will work on this system
  Fried control board nickfr 3 538 22-03-2024, 12:53 PM
  Computer controlled control panel dsbhachu1 0 263 18-02-2024, 11:35 AM
Last Post: dsbhachu1
  Replacement remote Chindley 1 1,920 06-12-2023, 03:00 PM
  TC fault code on Q60ar control board Skydive1710 3 3,547 20-11-2023, 03:12 PM
Last Post: NormanY
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,576 25-05-2023, 03:55 PM
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 4,180 02-12-2022, 02:51 PM
  CAM ZA3 Single control board Rookie 1 7,200 13-04-2022, 11:37 AM
  Master to slave remote problem Dingerb 0 1,614 24-12-2021, 01:26 PM
Last Post: Dingerb
  q60 ar control panel markythesparky 0 1,768 13-11-2021, 06:21 PM
Last Post: markythesparky
  455d FAAC FUSE IN CONTROL PANEL wildfig 0 2,116 04-10-2021, 02:34 PM
Last Post: wildfig
