  • 2 Vote(s) - 3.5 Average
CAM ZA3 Single control board
@page { size: 21cm 29.7cm; margin: 2cm } p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }
Hello help please
 I have a CAM ZA3 (222297) Single control board (about 10 years old) for my double gates the yellow flashing Cycle light has stopped working and trips the fuse, I have removed the live wire from the control board that stopped the fuse from tripping out, I next bypassed the control board and tested the Cycle flashing light with a 240v cable and works fine . advice please
With thanks Rookie
Rookie
(26-03-2022, 10:10 PM)Rookie Wrote: @page { size: 21cm 29.7cm; margin: 2cm } p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }
Hello help please
With thanks Rookie
Rookie
Hi Rookie,
thanks for the message,
this to me sounds like a possible cabling short and is unlikely to be the actual control panel, have you proved the cabling to the flashing light for shorts between the conductor at all, i feel this is the most plausible explanation as to why this is happening.
Kind Regards.
Joe.
  Fried control board nickfr 3 546 22-03-2024, 12:53 PM
  Computer controlled control panel dsbhachu1 0 266 18-02-2024, 11:35 AM
Last Post: dsbhachu1
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 458 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 1,797 09-02-2024, 06:13 PM
  TC fault code on Q60ar control board Skydive1710 3 3,553 20-11-2023, 03:12 PM
Last Post: NormanY
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,580 25-05-2023, 03:55 PM
  Replacement Q60A board? ndyhzlwd 1 1,933 10-02-2023, 03:19 PM
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 4,182 02-12-2022, 02:51 PM
  Beninca bob motor wiring to board Ranch2 6 4,227 18-11-2022, 09:59 AM
  q60 ar control panel markythesparky 0 1,768 13-11-2021, 06:21 PM
Last Post: markythesparky
