  • 177 Vote(s) - 2.97 Average
BFT Error 35 & 37 Not opening fully - SOLVED
HAve a DEIMOS ULTRA BT A600. Gate wont open fully.
Error 35 & 37 popping up - cant find out what it is.
Also a photocell has been hit recently ( can here relay working and gate working as expected when the cell is covered)
Any advice welcome!
(12-11-2017, 05:37 PM)razer raz Wrote: Hi,
Any advice welcome!
are you sure that was error 35/37 or Er 3H ?
did you try to open the gates manualy ?
Please see below the error codes.
Error code 35 - Opening obstacle motor 1
Error code 37 - Slowdown opening obstacle detection motor 1
I would check that there is nothing which could be causing an obstacle and check that the gate moves freely without any resistance spots, hope this helps.
(14-11-2017, 10:32 AM)TimK Wrote: Hi,
Thanks for the codes Smile
Ill have a look to see if anything is causing resistance ( this does corroborate with the display showing a higher load on the motor than the other leafs motor - which isn't presenting any error codes either)
All sorted gents.
Found debris underneath the guide rail, stopping the guide wheels passing by.
Once removed, gate runs smoothly!
Cheers!
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 17,997 26-09-2023, 05:32 AM
Last Post: max666
  Gates Opening After Closing tht7 2 9,630 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Robus 600 not closing fully All Well 11 9,144 03-08-2022, 02:42 PM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,385 24-06-2022, 09:54 AM
  Aria 400 - gates keep opening and closing objohnuk 1 4,201 13-04-2022, 11:32 AM
  Thalia P - BAR error devsolo 2 9,529 07-01-2021, 04:05 PM
Last Post: GilbertoMoncada
  Deimos BT 400/600 error codes orange 0 3,910 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 9,020 02-09-2020, 07:06 PM
Last Post: Adam67
  Strange gate opening issue (NICE) FrNiscars 3 23,152 09-11-2018, 09:48 AM
  Nice a60 opening issue raven2k1 1 7,653 09-09-2018, 05:17 PM
