  • 251 Vote(s) - 2.94 Average
Proteco q80s - Constant ST - constant open signal error
Question
My gate was fully wired and operating with an ACT A5 intercom/keypad. Over the weekend the gate kept opening. On investigation I found a constant ST error on the gate controller. This error is a constant start signal. I've checked and re done all the wiring and the only way to clear the error is to disconnect the keypad wiring to the gate controller. Has anyone ever had this error happen overnight for no apparent reason when the wiring is correct?
  Rigel 5 , gates won't open Nameloc 3 3,816 Yesterday, 11:38 AM
Last Post: Waltererele
  Came ZA3 gates stuck open Ivorwindybottom 0 398 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 1,878 02-10-2023, 09:20 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,033 26-09-2023, 05:32 AM
Last Post: max666
  Holding the Gate Open mgb 1 3,846 11-07-2023, 01:35 PM
Exclamation Proteco Q60A stopped working xCO 0 982 19-06-2023, 01:03 PM
Last Post: xCO
  Came gates stuck open. Ring8180 7 17,092 23-02-2023, 01:08 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 4,026 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 3,160 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,398 24-06-2022, 09:54 AM
