  • 207 Vote(s) - 2.6 Average
photocell error on Q60AR
I am trying to install new photocells on my system. I have checked and rechecked the wiring, but still am getting an "EF" fault on the control board. The set I am wanting to install is a FAAC XP15W.
I want to install those as can use a battery on 1 of the cells, but get the error if I wire them both into the board or utilise the battery
  Faac photocell stopped working Zeb Gulickx 2 1,135 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  Photocell Problem marcoos_1 4 19,415 04-01-2024, 10:23 AM
  TC fault code on Q60ar control board Skydive1710 3 3,657 20-11-2023, 03:12 PM
Last Post: NormanY
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,077 26-09-2023, 05:32 AM
Last Post: max666
  water damage to FAAC photocell Rajab 4 3,722 18-07-2022, 09:00 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,432 24-06-2022, 09:54 AM
  Proteco gates with photocell problem. Shane1 0 2,207 09-10-2021, 07:56 PM
Last Post: Shane1
  Thalia P - BAR error devsolo 2 9,652 07-01-2021, 04:05 PM
Last Post: GilbertoMoncada
  Deimos BT 400/600 error codes orange 0 3,951 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 9,057 02-09-2020, 07:06 PM
Last Post: Adam67
