  • 251 Vote(s) - 3 Average
mhouse wg2s not working as described
a litlle help needed with gates automation kit called mhouse wg2s by nice,i have a strange problem or feature which i don`t know how to solve.The problem is:
all buttons work as writen in manual except T3(remote is gtx4),it makes the same command as t1.T3 must to do only open(open) command,but makes OPEN(open-close) comand according to manual,if i press on controler p3 to make single cycle then t1 also makes only open command.I tried to program one of 2 remotes in mode 1 and mode 2 but everything is the same.Problem is still there.It seems open only comand doesn`t exist on complete cycle mode.Please don`t hesistate to ask additional questions if needed.To bring to warranty service is not an option Smile So would be nice to solve problem with your knowledgeSmile Maybe there is something i missed.
Seems a bit confusing but have you tried deleting the remote and re programming it?
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 534 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 1,331 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 1,453 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 8,522 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 3,917 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 3,294 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 7,300 30-05-2022, 09:15 AM
  Mhouse WS2 Gates not closing together pauln0301 1 5,255 13-04-2022, 11:18 AM
  Mhouse WG20 Alex74 1 5,821 04-02-2022, 11:05 AM
  WG2s Akis 2 3,737 11-01-2022, 11:38 AM
Last Post: Akis
