I have installed the easygate under ground system for double gate with CB11 control board . The close , open photo sensors are connected to the correct pins with correct polarities . Some how the close sensers do not work .if I swope the two ie with pins 17 and 18 only pin 18 works . The voltage on pins 17 is 24v ac/dc on pin 16 is 15volts ac/dc pin 19 is 24volts ac/dc . This is a new instalation can some one help on this .The sensors are all ok . The setup procedure has been done for the photo sensors .
LiftMaster CB11 Board Photocells
« Next Oldest | Next Newest »
Liftmaster LA400 | Defender | 6 | 9,800 |
03-08-2023, 12:26 PM Last Post: Torantrieb |
CB11 Multiple Keypad support | Pigsfoot | 1 | 2,231 |
12-08-2022, 08:14 AM Last Post: Michael |
odd liftmaster scs300-24 | scopie88 | 3 | 11,761 |
13-04-2022, 10:20 AM Last Post: JoeF |
Problem with delay time CB11 | milan | 2 | 10,934 |
04-10-2021, 01:44 AM Last Post: DesmondVog |
Liftmaster MYQ Internet Gateway Registration/Connection issues! | Carmody | 0 | 11,948 |
09-03-2021, 02:46 PM Last Post: Carmody |
Advice on new gate install - LIFTMASTER LYN424 | Leeb | 1 | 15,826 |
22-02-2021, 08:48 PM Last Post: russ |
Adding Extra Photocells To CB22 | Onoff | 0 | 5,223 |
06-08-2020, 01:01 AM Last Post: Onoff |
Liftmaster MYQ Internet gateway | koen_dc | 1 | 16,742 |
24-04-2020, 09:11 AM Last Post: RyanB |
Liftmaster CB1 gates started to open themselves | telnet123 | 4 | 25,492 |
01-01-2020, 09:43 AM Last Post: pronosoft |
chamberlain photocells | wlehane | 3 | 27,525 |
02-09-2019, 10:00 AM Last Post: Sav |
