  • 4 Vote(s) - 2.25 Average
Liftmaster LA400
Now that the Liftmaster LYN424 is no longer available and has been superseded by the LA400.
Can you tell me if the LA400 arm will work on an existing LYN424 system ,with a CB124EV controller,or will I have to purchase a new LA400 kit?
Many Thanks
(10-08-2022, 01:19 PM)Defender Wrote: Hi
Many Thanks
We found out the other week due to testing that the LA400 is a direct replacement for the LYN424 and does work with the CB124EV.
Hope this helps.
Many Thanks
Hope this helps.
Sam
Thanks for the update
Many Thanks
Hope this helps.
Many Thanks
Hope this helps.
Brilliant,
thank you.
Regards Joe
Hallo,
funktioniert das auch anders herum:
Kann ein LYN400-24 an dem neuen Board K001A6039 betrieben werden, da das CB24-Logic Board (K79-12815) nicht mehr lieferbar ist?
Freundliche Grüße
  odd liftmaster scs300-24 scopie88 3 11,661 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 11,880 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 15,755 22-02-2021, 08:48 PM
Last Post: russ
  Liftmaster MYQ Internet gateway koen_dc 1 16,667 24-04-2020, 09:11 AM
  Liftmaster CB1 gates started to open themselves telnet123 4 25,398 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 30,746 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 17,271 08-08-2017, 11:23 AM
  Liftmaster SCS300K - stop/go mtuk100 1 12,854 18-04-2017, 09:31 AM
  LiftMaster SUB300M + CB11 fault jonesy1991 0 10,813 25-01-2016, 02:51 PM
Last Post: jonesy1991
  Liftmaster xscs300-24 coops 2 13,426 10-08-2015, 03:49 PM
Last Post: coops
