  • 12 Vote(s) - 2.67 Average
Liftmaster MYQ Internet Gateway Registration/Connection issues!
Hi there,
My Liftmaster MyQ internet gateway was working fine until I switched broadband providers at which point it refused to connect to my new router.  Sad I checked the Liftmaster website and confirmed that my Virgin Router (Virgin Hub 3.0/VMDG505) is not listed as incompatible with the gateway.  I have tried different router ports, soft and hard resets of the gateway and even deleted it from my MyQ list of devices in the hope that I could reconnect it as a new device.  All to no avail.
The MyQ team based in the US say my gateway device appears OK to them and are blaming my "new router operating at a higher speed than the gateway can keep up with". Which is kind of b*llocks as I've actually downgraded my broadband internet speed! They say I need to buy and use something called a "cross over cable".
Symptoms
  1. When I try to set up the gateway using the MyQ app by entering the gateway's serial number, I get error code 310. The guides say that means the gateway is on another user's account and unable to register. (Since I have removed the gateway from my account, how can this be? Is this something the MyQ team have to resolve in their own database?)
  2. When I try hard or soft resets as per manufacturer instructions, the green and blue lights on the gateway flash briefly, then the orange, then nothing.  The green light is supposed to stay on to show the device has connected to my router. There is no problem with power and all ports of my router are operating fine with other devices.
Any advice or tips would be greatly appreciated!!!
Carmody
  Liftmaster LA400 Defender 6 9,705 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 11,670 13-04-2022, 10:20 AM
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 15,763 22-02-2021, 08:48 PM
Last Post: russ
  Liftmaster MYQ Internet gateway koen_dc 1 16,675 24-04-2020, 09:11 AM
  Liftmaster CB1 gates started to open themselves telnet123 4 25,408 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 30,750 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 17,272 08-08-2017, 11:23 AM
  Liftmaster SCS300K - stop/go mtuk100 1 12,855 18-04-2017, 09:31 AM
  LiftMaster SUB300M + CB11 fault jonesy1991 0 10,814 25-01-2016, 02:51 PM
Last Post: jonesy1991
  Liftmaster xscs300-24 coops 2 13,429 10-08-2015, 03:49 PM
Last Post: coops
