  • 167 Vote(s) - 2.84 Average
Proteco Q36S problem
(11-07-2015, 12:47 PM)PITCHOUNE Wrote:
(30-07-2014, 11:44 AM)dan_tm Wrote: Hello,
I have a Proteco Q36S sliding door automatisation installed at my home.
Could you please help me with a wiring diagram for this type of module?
There are some copper traces damaged on the back of the module.
Thanks and regards,
Daniel
hello
I have a Proteco Q36 system. The motherboard is obsolete (at the end of manufacturing), the only solution of repair is to repair directly the electronic board
Could you please help me with the wiring diagram of the control board (diagram with electronic component) ? I add a picture of the motherborad.
Thanks and regards,
PITCHOUNE
Hello,
I found the breakdown of main supply on my motherboard Q36. However, on the exits 8 and 9 I have a continuous tension of 30 volts while it would seem that are needed 24 volts.
Somebody can make the measure (can import the type of motherboard Q36S, Q36, Q60SR.....)?
According to the statement of measure made from the transformer 230V / 24V, and the wiring diagram which follows, it does not seem inconsistent be 30 volts but me will like being sure there. To specify that the motherboard seems to work in spite of these 30 volts ("--" on the digital display), l has only the part motorization there which I can have to to test (not the engine and "Mr" on the digital display after action with the remote).
Thanks and regards
PITCHOUNE (France):cool:
Proteco Q36S problem - by dan_tm - 30-07-2014, 11:44 AM
RE: Proteco Q36S problem - by PITCHOUNE - 11-07-2015, 12:47 PM
RE: Proteco Q36S problem - by PITCHOUNE - 01-08-2015, 11:01 PM
  Photocell Problem marcoos_1 4 19,532 04-01-2024, 10:23 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,124 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 1,015 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 4,108 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 3,247 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,475 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 2,653 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 1,782 12-01-2022, 08:13 PM
Last Post: Shane1
  Master to slave remote problem Dingerb 0 1,646 24-12-2021, 01:26 PM
Last Post: Dingerb
  Proteco Leader N1 problem Luc Bevers 0 2,102 22-10-2021, 09:57 AM
Last Post: Luc Bevers
