  • 9 Vote(s) - 2.44 Average
MHouse SL1-10 partial close
(28-05-2022, 04:56 AM)NAT Wrote:
(16-05-2022, 11:49 AM)SamA Wrote:
(08-05-2022, 11:43 AM)NAT Wrote:
(03-05-2022, 10:08 AM)SamA Wrote: Hi Nat,
It sounds as though it could be something mechanical on the gate causing it to see an obstruction, when the fault occurs what does the ECSbus LED flash? When you manually release the gate and push it from open to closed does any friction occur?
Hi SamA,
Thank you for your response. Apologies for only just seeing it.
I did as you suggested and the gate manually opens and closes freely past the problem point.
I even gave it a firm push as it was closing automatically and it fought against me from the same point where it gradually slows down before coming to a stop. It's the same sequence it does once it approaches the fully closed position.
Regarding ECSbus flashing: when issuing open or close comand there's 4 long flashes. Once it reaches the fully closed or fully open point and stops there's 2 long flashes. When the gate stops at the problem location when closing there's no long flashes, the constant quick flashing just keeps going uninterupted.
Any ideas what this means?
2 long flashes means the photocell is being triggered at a certain point and 4 flashes mean that the stop input is being triggered. Try taking out all of your accessories such as anything wired into stop, ecsbus, open, close, pp, sbs. Do an Ecsbus search by pressing and holding P2 button for 3 seconds the release. Wait until LED 2 goes off and then try the gate. If the problem clears, reintroduce the accessories one by one by plugging one accessory in and doing the ECSbus search as mentioned above until you find what is causing the issue.
Hi SamA,
Thanks for the tip. I followed your suggestions and even with all accesories removed and then re-learning the ecsbus it still comes to a gradual stop at about 1/3 closed. Same as before it doesn't do it when learning the gate limits.
Do you have any other ideas I could try?
Hi Nat,
I would recommend doing a full reset of the board. This is done by pressing and holding P2 and P3 together for around 10 seconds then release. Wait around 10 further seconds and take out all of your accessories such as anything wired into stop, ecsbus, open, close, pp, sbs. Do an Ecsbus search by pressing and holding P2 button for 3 seconds the release. Wait until LED 2 goes off and then try the gate. If the problem still occurs, manually release the gate and put it halfway and lock it back into electric mode. Then press and release P3 and the gate should relearn its limits.
Kindest Regards,
MHouse SL1-10 partial close - by NAT - 24-04-2022, 10:04 AM
RE: MHouse SL1-10 partial close - by SamA - 03-05-2022, 10:08 AM
RE: MHouse SL1-10 partial close - by NAT - 08-05-2022, 11:43 AM
RE: MHouse SL1-10 partial close - by SamA - 16-05-2022, 11:49 AM
RE: MHouse SL1-10 partial close - by NAT - 28-05-2022, 04:56 AM
RE: MHouse SL1-10 partial close - by SamA - 30-05-2022, 09:15 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 764 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 1,638 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 1,715 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 9,371 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 4,234 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 3,572 19-08-2022, 09:29 AM
  Mhouse WS2 Gates not closing together pauln0301 1 5,343 13-04-2022, 11:18 AM
  Mhouse WG20 Alex74 1 5,914 04-02-2022, 11:05 AM
  MHouse WS2S Bricodust 2 9,602 30-03-2021, 01:26 PM
Last Post: Bricodust
  MHouse WG2 Manual Release mousetarget 1 7,672 30-03-2021, 12:21 PM
