  • 5 Vote(s) - 2 Average
Proteco Leader N1 problem
Hello,
I have a Proteco Leader TI swing gate where motor was broken. After replacement, motor works for only a few seconds and then stops. Each time a start command is given, the same happens: motor runs for a few seconds and stops again. Fault notification on control board = N1. I have switched both swing gate motors to check whether it's motor related, but the problem remains: after switching, the other motor runs a few seconds and stops. Capacitor has been replaced as well; all wiring double checked since N1 is related to communication error between motor and control board??
Does anyone have suggestions?
  Photocell Problem marcoos_1 4 19,534 04-01-2024, 10:23 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,127 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 1,016 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 4,110 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 3,250 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,476 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 2,653 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 1,783 12-01-2022, 08:13 PM
Last Post: Shane1
  Master to slave remote problem Dingerb 0 1,646 24-12-2021, 01:26 PM
Last Post: Dingerb
  Proteco gates with photocell problem. Shane1 0 2,218 09-10-2021, 07:56 PM
Last Post: Shane1
