  • 345 Vote(s) - 2.78 Average
DEIMOS BT Issue - Advice please
I have a Deimos BT sliding a solid one piece wooden gate. it has 2 mitto transmitters, cellula 130 photocells, intercom, with 2 internal handsets.
Couple of days ago when trying to close it got half way across then went back to staying permanently open, it then sat there and wouldnt close, intercom manual input of number did nothing, pressing keyfob did nothing, so i closed it manually with lock off then put lock back on. This morning, when i tried to open again with keyfob, the grey motor box was making a noise but not moving the gate, so had to open and close manually again. unfortunately the git that fitted it in May 07 who charged a fee for 2 years maintenance as gone awol.
could the cold weather have affected it ? it has been about minus 7 at night ???
Any advice guys would be greatly appreciated
thanks
All electric motors can be affected by temprature and there maybe a force adjuster on the circuit board to alter the electrical force the motor uses. These are a part of the Antisquash marked as AMPO and AMPC .
But this fault could also be caused by the Photocells being faulty or blocked or frozen up
I would check the photocells and connections first the alter the antisquash adjusters - But allways refer to the original instruction manual for you system before making any adjustments
  BFT Rigel 5 issue Adamit 0 74 17-05-2024, 10:28 AM
Last Post: Adamit
  Question BFT Deimos A400 Makaroni 0 133 15-05-2024, 08:05 AM
Last Post: Makaroni
  Gate wont close issue MR_ROBOT 3 10,143 11-04-2024, 08:08 AM
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 6,981 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 1,178 05-03-2024, 04:17 PM
  BFT Rigel 5 Issue kw1 0 9,686 16-08-2020, 02:04 PM
Last Post: kw1
  Advice on photocells for BFT gates weave 1 5,764 14-04-2020, 01:34 PM
  BFT Leo B issue - KO JamesHK 0 4,278 16-06-2019, 04:26 PM
Last Post: JamesHK
  BFT Deimos Ultra remote problems shaggy 1 11,439 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos Ultra BT A 600 + Tbox ok.dude 1 6,821 30-04-2019, 09:32 AM
Last Post: ok.dude
