  • 12 Vote(s) - 2.42 Average
Advice on photocells for BFT gates
Hi All
My swing gates open using BFT Oro system. Today they will not close as I believe the photocells are broken. I tried replacing the battery on the one that’s not connected to the control unit but no change.
Having looked online I believe the photocells are BFT 2241 also referred to as SEAV 2241. Available for about £100 for the pair.
Can I just swap them out without needing to do anything at the control unit?
Steve
You would just need to swap these over. Ensuring your power for the RX is going to the correct terminals and ensuring you wire the cells normally closed and common going back to the safety input on the control panel.
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,781 10-10-2022, 10:07 AM
  Best BFT for closed aluminium gates rafp 1 3,039 13-04-2022, 11:38 AM
  BFT controlled gates open but don't close MikeJep 5 19,889 04-01-2022, 09:58 AM
  Gates not closing (BFT Thalia btl2 and Bft Desme) Joel23M 2 7,784 17-01-2021, 01:25 PM
Last Post: Joel23M
  Help with bft compacta photocells Kev132 0 2,654 09-12-2020, 06:49 PM
Last Post: Kev132
  Altair-P gates now move in opposite direction with any change to wiring william.helsby 1 6,905 24-05-2020, 08:08 PM
Last Post: william.helsby
  Wiring Compacta photocells to Rigel 5 rjmoore 0 10,998 11-05-2020, 06:51 PM
Last Post: rjmoore
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 57,954 23-04-2019, 10:11 AM
  BFT wooden gates won’t open Dreddy88 0 6,392 10-08-2018, 07:46 PM
Last Post: Dreddy88
  How to periodically keep gates open ?? !! thomasario 6 40,421 13-03-2018, 04:35 PM
Last Post: thomasario
