  • 326 Vote(s) - 2.86 Average
Genius 592 Control Board
Can anyone help, my gate motors need 240v but they are only getting 120v out of the connection in the control board. Therefore the gate motors are overheating with the motor being on but not operating the gates. How can we rectify the problem.
Guest Wrote:Can anyone help, my gate motors need 240v but they are only getting 120v out of the connection in the control board. Therefore the gate motors are overheating with the motor being on but not operating the gates. How can we rectify the problem.
The gates are not overheating because of the 120V. If you have 120V coming out of the board it may mean it is in slow down mode or the force is set very low. You should look at re-learning your gates. If the gates are not operating at all, the first thing to do is try changing the capacitor as this would cause them to stop working and buzz and get hot.
You can purchase a capacitor or a new control board from us by calling 0845 054 50 70.
Attached are instructions for the Genius 592 control panel which should help you along.
Hope this helps.
.pdf   592.pdf (Size: 961.52 KB / Downloads: 2,078)
  Circuit board disabled CB124 - 7 flashes Tussun 6 21,732 15-08-2025, 01:57 PM
  New enclosure for existing control panel BenH 0 2,150 05-06-2024, 12:49 AM
Last Post: BenH
  Fried control board nickfr 3 5,643 22-03-2024, 12:53 PM
  Computer controlled control panel dsbhachu1 0 2,403 18-02-2024, 11:35 AM
Last Post: dsbhachu1
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 3,803 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 6,824 09-02-2024, 06:13 PM
  Genius JA592 issue fintaneduffy 3 5,843 19-01-2024, 09:58 AM
  TC fault code on Q60ar control board Skydive1710 3 10,126 20-11-2023, 03:12 PM
Last Post: NormanY
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,917 25-05-2023, 03:55 PM
  Replacement Q60A board? ndyhzlwd 1 5,823 10-02-2023, 03:19 PM
