  • 14 Vote(s) - 3.21 Average
New enclosure for existing control panel
Hi, I inherited a 'less-than-professional' installation of CAME automated gate. Height of original CAME control panel box is very close to ground level and attracted slugs. It is also too crowded to include additional accessories such as loop detector & intercom PSU. I would like to put CAME case (with other components) into a roomier outdoor box (IP65 or IP66) and can't decide between plastic vs steel. Steel may be more durable but is about 3 times heavier (and expensive) - is a plastic (ABS) enclosure would be a good enough choice for this?
Also, the above CAME box is vented (front) - does this mean I better have some vents in the new box as well or can the bigger enclosure be a fully sealed one?
  Fried control board nickfr 3 5,644 22-03-2024, 12:53 PM
  Computer controlled control panel dsbhachu1 0 2,406 18-02-2024, 11:35 AM
Last Post: dsbhachu1
  TC fault code on Q60ar control board Skydive1710 3 10,128 20-11-2023, 03:12 PM
Last Post: NormanY
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,922 25-05-2023, 03:55 PM
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 12,188 02-12-2022, 02:51 PM
  CAM ZA3 Single control board Rookie 1 11,122 13-04-2022, 11:37 AM
  q60 ar control panel markythesparky 0 3,711 13-11-2021, 06:21 PM
Last Post: markythesparky
  455d FAAC FUSE IN CONTROL PANEL wildfig 0 4,192 04-10-2021, 02:34 PM
Last Post: wildfig
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,605 02-05-2021, 09:00 PM
Last Post: soother
  Control Box for Gate Automation jimhon 0 8,773 19-06-2020, 10:27 AM
Last Post: jimhon
