  • 280 Vote(s) - 2.85 Average
Daitem SC9200AU Controller to Nice MC824
I've wired the controller up as described in your tech sheet but the controller only opens the gate. I don't have the gates auto closing so would like to be able to close them using the handset. Is this possible?, cheers.
Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
The daitem is only designed to open a gate, then automatically close it "if set on the gate panel" that's why it cannot tell if the gate is open or closed,
(10-10-2014, 12:59 PM)Shropshire fella Wrote: Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
  Nice Robus closing after photo Nexur 1 7,662 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 10,076 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 8,357 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,037 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,711 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,821 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 5,440 16-02-2025, 05:16 PM
Last Post: gatekeeper
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,237 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,913 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 8,365 10-12-2024, 10:31 AM
Last Post: dmrgate
