  • 294 Vote(s) - 2.78 Average
aster 5 gate adjustment
my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Guest Wrote:my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Hi, you should have physical gate stops in the ground to stop the motor running to the end of its reach. also there should be a function on the board to decrease the motor run time, or there maybe a function to learn where the gates open and close to. you should refer to the manual for this information.
Hope this helps
  Help me identify this mystery gate opener alpha 4 1,315 11-08-2025, 03:42 PM
  Peculiar automatic gate behavior Gatefreak 1 2,431 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 2,244 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 2,289 18-03-2025, 06:40 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 29 46,602 27-02-2025, 03:08 PM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 7,659 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 3,284 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 2,952 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 3,280 28-08-2024, 05:13 AM
Last Post: drewdavis
  Trying to identify this Gate Controller - HOCHE UC109? RossAM 0 3,322 02-08-2024, 04:47 PM
Last Post: RossAM
