  • 191 Vote(s) - 2.92 Average
BFT Error 35 & 37 Not opening fully - SOLVED
(14-11-2017, 10:32 AM)TimK Wrote: Hi,
Please see below the error codes.
Error code 35 - Opening obstacle motor 1
Error code 37 - Slowdown opening obstacle detection motor 1
I would check that there is nothing which could be causing an obstacle and check that the gate moves freely without any resistance spots, hope this helps.
Thanks for the codes Smile
Ill have a look to see if anything is causing resistance ( this does corroborate with the display showing a higher load on the motor than the other leafs motor - which isn't presenting any error codes either)
RE: BFT Error 35 & 37 Not opening fully - by Tim - 14-11-2017, 10:32 AM
RE: BFT Error 35 & 37 Not opening fully - by razer raz - 14-11-2017, 01:13 PM
  came bx-b clicking & not opening misssmith 1 3,103 13-03-2025, 09:57 AM
  Thalia P - BAR error devsolo 3 17,951 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,041 17-01-2025, 10:06 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,423 26-09-2023, 05:32 AM
Last Post: max666
  Gates Opening After Closing tht7 2 15,363 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Robus 600 not closing fully All Well 11 22,847 03-08-2022, 02:42 PM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,884 24-06-2022, 09:54 AM
  Aria 400 - gates keep opening and closing objohnuk 1 7,952 13-04-2022, 11:32 AM
  Deimos BT 400/600 error codes orange 0 5,962 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 11,183 02-09-2020, 07:06 PM
Last Post: Adam67
