  • 239 Vote(s) - 2.75 Average
BFT Deimos QSC D not accepting new mitto remotes
I'm definitely pressing the hidden button. I have the egg shaped Mitto remotes that need you to press the internal button with a thin screwdriver. On the Deimos BT QSC board, it recognises the hidden button being pressed on the 'Add Start' menu, but always just shows 'Ko' after subsequently pressing T1.
If I read the two working remotes on the QSC board they are 04t1 and 05t2 (second functions are programmed to switch a relay also).
On the Clonix, which is wired to the QSC via terminals 13(Blue) 12 (Brown), when I try to program by pressing the SW1 button, it starts blinking, I press the hidden button until LED remains on, then I hit T1 and the LED just goes out. Nothing is stored however.
Best regards,
RE: BFT Deimos QSC D not accepting new mitto remotes - by roadrunner - 06-08-2016, 08:09 PM
  BFT Deimos issue erickavo 2 2,937 09-07-2025, 11:34 AM
  Deimos BT 400/600 error codes orange 0 6,003 07-12-2020, 09:36 AM
Last Post: orange
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 6,415 28-11-2019, 12:11 AM
  BFT Deimos BT Error Codes rajesh 1 21,352 05-06-2017, 11:07 AM
  daitem handset faac gates & remotes doon1968 0 8,885 28-08-2016, 05:12 PM
Last Post: doon1968
  BFT Deimos QSC D second function relay for external lights roadrunner 0 7,255 08-08-2016, 05:42 PM
Last Post: roadrunner
  BFT Deimos QSC D LED display stuck on 'cLS' roadrunner 1 11,382 01-08-2016, 08:45 PM
  Programmable remotes David Etra 3 19,598 22-07-2015, 10:14 AM
Last Post: Blakey111
  Gate remotes stopped working Steviev1 1 17,500 03-01-2015, 12:01 PM
  Proteco gate code remotes stroller 1 16,481 12-06-2012, 09:50 AM
Last Post: Proteco_UK
