  • 237 Vote(s) - 2.89 Average
Help with Proteco Slower4 connections
If you can afford it, just buy a new control board for swing gate operators. Your operator is a typical 230VAC operator and compatible with any board for 230VAC swing gate operators you can find. You will also need remotes, a capacitor for the operator (8 μF ?) and safety photocells.
Good luck.
PS: It is very possible that the board will not function correctly, even if you reinstall the transformer. And this is not counting that as you said you have no installation manual. I couldn't locate any info on S.A.T. and nobody I asked knew it either. You will probably have a hard time trying to find a manual for a 10-15 years old obscure piece of electronics.
RE: Help with Proteco Slower4 connections - by thm - 10-10-2014, 08:30 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,736 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,514 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,511 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,735 12-07-2022, 11:48 AM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,966 12-01-2022, 08:13 PM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,345 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,199 09-10-2021, 07:56 PM
Last Post: Shane1
  Proteco Aster 3 ram fault soother 2 8,690 14-07-2021, 11:58 PM
Last Post: soother
