  • 295 Vote(s) - 2.81 Average
NIce ME310 motors keep fusing
Hi Matt, this is great! Thank you for taking the time to reply. I will check out the drainage issue as I suspect this is where the problem has stemmed from.
Cheers
Andre
Hi, can someone please help. I have replaced x2 Nice ME310 motors a year ago and all been working fine until recently. They seem to be ok when the weather is dry but as soon as there is moisture in the air or rain they fuse in a particular position. The connections to the main junction box are dry so sure this is not the problem. I have unbolted the motors and looked at the bottom of the units and there does seem to be alittle corrosion, but I have put this down to them sitting in water in the ground from time to time when there is a downpour. I have submerged one of the boxes in water and the system did fuse. But now all has dryed out... it's still fusing. They do fuse the main house not just within the junction box but struggling to know whether the motors have penetrated water or it is something else. They are both only a year old! Any ideas?
Any help would be great or tests.
Thanks in advance
[/quote]
Being an installer of gate automation I have seen this issue frequently on jobs that we have taken over. On initial install of underground motors one of the most important things which is often overlooked is to put in suitable drainage for the motors. Yes these motors are designed to withstand water but only for a limited amount of time because eventually water will get through the seals and damage your motor head. On each foundation case there are holes pre made in the sides, this is where the installer should put a soak away into eg conduit into a drain etc etc. And a good test to see if it is sufficient is to poor water into the foundation case (enough to fill it) and it must be gone within 20 mins. (Before motors are put in)
If drainage has been installed then on your annual service or something you should of been informed to undertake is to make sure the drainage isn't blocked from mud etc.
I'm sorry to say but this is something that manufactures will not replace under warranty (I no first hand as I was a technician for a leading one)
You have 3 options really, use then and let it keep tripping your RCD as soon as it rains. Leave them on manual override and have no automation, or call an engineer out who is recommended by a manufacture such as NICE CAME BFT etc.
I have been to many properties of poorly installed motors, and have seen them in for less than 3 months having this problem.
I would add that of drainage has been installed and is sufficient, then get your original installer to come out to you.
I hope this helps. These motors on a domestic property with an annual service should be good for 10 years.
Cheers
Matt
[/quote]
NIce ME310 motors keep fusing - by Andre007 - 29-08-2014, 06:48 PM
RE: NIce ME310 motors keep fusing - by Andre007 - 06-09-2014, 02:12 PM
  Nice LFAB occasionally failing open DaveHG 3 10,094 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 8,364 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,047 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,721 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,828 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 5,442 16-02-2025, 05:16 PM
Last Post: gatekeeper
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,925 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 8,372 10-12-2024, 10:31 AM
Last Post: dmrgate
